The K70 RGB RAPIDFIRE gaming keyboard has Cherry MX Speed RGB switches backed by a lightweight, durablealuminum frame. Advanced lighting control and large font keycaps deliver dynamic, vibrant multi-color backlighting. Harness the power of CUE for sophisticated macro programming and dramatic lighting effects and animations. 100% anti-ghosting with full key rollover on USB helps ensure accuracy, so every keystroke translates directly into accuratengameplay. The USB pass-through port is positioned for uninterrupted game play and ready for your mouse or wireless headset adapter. Contoured, textured FPS and MOBA key sets keep you in control, and the Cherry MX Speed RGB switches give you linear response and fast actuation
Amazing speed
Unleash blistering speed with the mechanical actuation and durability of mechanical gaming key switches. Wield the performance advantage over your opponents with light operation key switches and a faster actuation. -
Durability meet invincibility
The aircraft-grade anodized brushed aluminum frame is built to withstand a lifetime of keystrokes, so you'll never jam up at the wrong moment. -
Anti-ghosting
Full key rollover and anti-ghosting technology means, that no matter, how fast your in game actions, the RAPIDFIRE can keep up, registering every keypress correctly, every time. -
Experience dynamic, vibrant multi-color backlighting for virtually unlimited customization.
- CORSAIR Gaming K70 RGB RAPIDFIRE Mechanical - keyboard - UK - anodised brushed aluminium Input Device
- Keyboard
- Backlit
- RGB
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Hot Keys Qty
- 6
- Hot Keys Function
- Multimedia, volume, macros buttons, Windows key lock
- Numeric Keypad
- Gaming
- Key Switch Type
- CHERRY MX Speed
- Anodised brushed aluminium
- 43.6 cm x 16.5 cm x 3.8 cm
- 1.2 kg
- 2-year warranty
- Keyboard
- Backlit
- RGB
- Interface
- USB
- Hot Keys Qty
- 6
- Hot Keys Function
- UK
- Keyboard Technology
- Mechanical
- Key Switch Type
- CHERRY MX Speed
- Gaming
- Palm Rest
- Numeric keypad
- 43.6 cm
- 16.5 cm
- 3.8 cm
- 1.2 kg
- Included Accessories
- FPS and MOBO keycap sets
- OS Required
- Microsoft Windows Vista / 7 / 8 / 10
- Limited warranty - 2 years
