The HARPOON RGB mouse is built to perform, featuring a 6000 DPI optical gaming sensor with advanced tracking for precise control and lightweight, contoured design to support the quickest of movements.
Game in the Fast Lane:
Play with hyper-fast, sub-1ms SLIPSTREAM CORSAIR WIRELESS TECHNOLOGY, or connect with low-latency Bluetooth or USB wired. -
Weighs Just 99g:
Lightweight construction, so you can play longer without fatigue. -
Simple Setup Gets You Playing Faster:
Just connect the wireless adapter to a USB port and switch the mouse on. -
Contoured Shape and Rubber Side Grips:
For long-term comfort and a confident grip. -
Up to 60 hours of Battery Life :
Play uninterrupted with battery life that lasts for days, or plug in for wired mode to keep playing while charging. -
Six Fully Programmable Buttons:
Play your way with powerful macros and remaps for an in-game advantage. -
Ultra-Durable Omron Switches:
Rated for more than 50 million clicks. -
10,000 DPI Optical Sensor:
For high-accuracy tracking of even the slightest movement. -
Dynamic RGB Lighting:
Choose from dozens of stunning customizable lighting presets and effects, or create your own. -
Intelligent Control, Unlimited Possibilities:
Vivid dynamic RGB lighting control, sophisticated macro programming and full-system lighting synchronization compatible CORSAIR peripherals, coolers, fans and more.
- CORSAIR Gaming HARPOON RGB - mouse - USB
- Mouse
- Connectivity Technology
- Wired - USB
- 6.83 cm x 11.15 cm x 4.04 cm
- 85 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 6
- Movement Resolution
- 6000 dpi
- Performance
- Realtime sensitivity switching 250 - 6000 dpi
- Programmable buttons, rubber side grips, polytetrafluoroethylene (PTFE) feet, built-in flash memory, Corsair Utility Engine (CUE)
- Cable Length
- 1.8 m
- OS Required
- Microsoft Windows 7 / 8 / 10
- 2-year warranty
- Mouse
- 6.83 cm
- 11.15 cm
- 4.04 cm
- 85 g
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 6
- 6000 dpi
- Performance
- Cable Length
- 1.8 m
- 1 x USB 2.0 - 4 pin USB Type A
- OS Required
- Limited warranty - 2 years
