Corsair Gaming HARPOON RGB Gaming Mouse Backlit RGB LED, 6000 DPI
Quicklinx: CGKMWS00 Mfr#: CH-9301011-EU
The HARPOON RGB mouse is built to perform, featuring a 6000 DPI optical gaming sensor with advanced tracking for precise control and lightweight, contoured design to support the quickest of movements.
  • Game in the Fast Lane:
    Play with hyper-fast, sub-1ms SLIPSTREAM CORSAIR WIRELESS TECHNOLOGY, or connect with low-latency Bluetooth or USB wired.
  • Weighs Just 99g:
    Lightweight construction, so you can play longer without fatigue.
  • Simple Setup Gets You Playing Faster:
    Just connect the wireless adapter to a USB port and switch the mouse on.
  • Contoured Shape and Rubber Side Grips:
    For long-term comfort and a confident grip.
  • Up to 60 hours of Battery Life :
    Play uninterrupted with battery life that lasts for days, or plug in for wired mode to keep playing while charging.
  • Six Fully Programmable Buttons:
    Play your way with powerful macros and remaps for an in-game advantage.
  • Ultra-Durable Omron Switches:
    Rated for more than 50 million clicks.
  • 10,000 DPI Optical Sensor:
    For high-accuracy tracking of even the slightest movement.
  • Dynamic RGB Lighting:
    Choose from dozens of stunning customizable lighting presets and effects, or create your own.
  • Intelligent Control, Unlimited Possibilities:
    Vivid dynamic RGB lighting control, sophisticated macro programming and full-system lighting synchronization compatible CORSAIR peripherals, coolers, fans and more.
CORSAIR Gaming HARPOON RGB - mouse - USB
Mouse
Wired - USB
6.83 cm x 11.15 cm x 4.04 cm
85 g
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
6000 dpi
Performance
Realtime sensitivity switching 250 - 6000 dpi
Programmable buttons, rubber side grips, polytetrafluoroethylene (PTFE) feet, built-in flash memory, Corsair Utility Engine (CUE)
Cable Length
1.8 m
Microsoft Windows 7 / 8 / 10
Mouse
6.83 cm
11.15 cm
4.04 cm
85 g
Input Device
Wired
USB
Optical
Buttons Qty
6
Movement Resolution
6000 dpi
Performance
Cable Length
1.8 m
1 x USB 2.0 - 4 pin USB Type A
