Corsair Gaming GLAIVE RGB Gaming Mouse Backlit RGB LED
Quicklinx: D8RBWS00 Mfr#: CH-9302111-EU
Corsair GLAIVE RGB is the ultimate gaming mouse in performance and comfort. The contoured shape is designed for extended play. A custom high-accuracy optical gaming sensor ensures maximum performance. Onboard profile storage saves lighting effects, macros and DPI settings for universal access to your settings on any PC. An aluminum scroll wheel with rubber grip guarantees solid response and accuracy.
CORSAIR Gaming GLAIVE RGB - mouse - USB - black
Mouse
Wired - USB
9.15 cm x 12.58 cm x 4.46 cm
122 g
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
16000 dpi
Performance
125/250/500/1000 reports per second, realtime sensitivity switching 100 - 16000 dpi
Polytetrafluoroethylene (PTFE) feet, built-in flash memory, braided cable, Corsair Utility Engine (CUE), 3-zone illumination, RGB LED backlight
Cable Length
1.8 m
Mouse
9.15 cm
12.58 cm
4.46 cm
122 g
Product Material
Aluminium
Input Device
Wired
USB
Optical
Buttons Qty
6
Movement Resolution
16000 dpi
Performance
Cable Length
1.8 m
1 x USB - 4 pin USB Type A
Accessories case, 2 thumb grips
