Corsair GLAIVE RGB is the ultimate gaming mouse in performance and comfort. The contoured shape is designed for extended play. A custom high-accuracy optical gaming sensor ensures maximum performance. Onboard profile storage saves lighting effects, macros and DPI settings for universal access to your settings on any PC. An aluminum scroll wheel with rubber grip guarantees solid response and accuracy.
- CORSAIR Gaming GLAIVE RGB - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- 9.15 cm x 12.58 cm x 4.46 cm
- 122 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 6
- Movement Resolution
- 16000 dpi
- Performance
- 125/250/500/1000 reports per second, realtime sensitivity switching 100 - 16000 dpi
- Polytetrafluoroethylene (PTFE) feet, built-in flash memory, braided cable, Corsair Utility Engine (CUE), 3-zone illumination, RGB LED backlight
- Cable Length
- 1.8 m
- 2-year warranty
- Mouse
- 9.15 cm
- 12.58 cm
- 4.46 cm
- 122 g
- Product Material
- Aluminium
- Black
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 6
- 16000 dpi
- Performance
- Cable Length
- 1.8 m
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Accessories case, 2 thumb grips
- Limited warranty - 2 years
