Based on the Sandforce controller, the Corsair Force Series Solid-State Drive offers stutter-free response, fast performance, cooler and quieter operations for your notebook, netbook, and desktop PC.
If speed is what you are looking for and what you expect from your performance or gaming system the Corsair Force Series SSD's are the perfect choice. Based on the Sandforce controller, the Corsair Force Series SSD's are the ultimate performance drive. Your system will start-up faster, applications and games will load quicker and you will see a huge improvement in overall system responsiveness. The Corsair Force Series SSD is the ultimate SSD for your demanding storage requirements.
Affordable SSD performance
The Force MP500 allows you to access all of your data, load files and launch games faster. -
Compact form factor
CORSAIR NVMe M.2 SSDs enable a higher level of performance in a compact form factor. -
Enhanced error correction
Additional error bit correction and improved data retention while supporting advanced NAND. -
Toughened contact surface material
The extra thickness improves contact to the motherboard, and provides vibration resistance to ensure reliability in vigorous conditions. -
Lower power consumption
Lower power consumption results in better energy efficiency and longer battery life with laptops.
- CORSAIR Force Series MP500 - SSD - 240 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 240 GB
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- M.2 2280
- Interface
- Enhanced Error Correction Code, Dynamic and Static Wear Leveling, S.M.A.R.T.
- 22 mm x 80 mm
- 82 g
- 3-year warranty
- Capacity
- 240 GB
- Form Factor
- M.2 2280
- Interface
- 22 mm
- 80 mm
- 82 g
Performance
- SSD Endurance
- 349 TB
- Internal Data Rate
- 3000 MBps (read) / 2400 MBps (write)
Expansion & Connectivity
- 1 x PCI Express 3.0 x4 (NVMe)
- Compatible Bay
- M.2 2280
- OS Required
- Apple MacOS X, Windows 10
- Limited warranty - 3 years
- 0 °C
- 65 °C
- 0 - 90%
- Shock Tolerance (operating)
- 1500 g
- Shock Tolerance (non-operating)
- 1500 g
