Corsair Flash Voyager Vega 64GB
Quicklinx: 9RZ4WS00 Mfr#: CMFVV3-64GB
Flash Voyager Vega is ultra-compact, fast, and a perfect complement for the latest ultra-slim PCs, car audio systems, or anywhere you want a lot of storage in a discreet design. The scratch-resistant hard chrome plated zinc alloy housing features an integrated loop for securely attaching to your key ring. Compatibility is no problem - you get USB 3.0 speed on the latest systems and full USB 2.0 support on mainstream PCs.
  • Ultra-compact design
    Flash Voyager Vega is so small that you can leave it in your notebook's USB port and take it everywhere you go.
  • It's not just for PCs
    The small size also makes it perfect for the latest car audio systems, or any device which has a standard USB port. You can take your music collection with you everywhere, without the bulk of a traditional USB flash drive.
  • USB 3.0 speed with universal USB 2.0 compatibility
    You'll get super-fast file access on the latest PCs, and full support on mainstream systems. And, of course, it works with Windows, OS X and Linux with no driver installation necessary.
  • Scratch resistant
    Scratch resistant, hard chrome plated zinc alloy housing with blue activity LED. The sophisticated look goes great with the latest ultra-slim systems.
  • One-piece design with an integrated key loop
    Your Flash Voyager Vega securely attaches to your key ring when you're on the go.
CORSAIR Flash Voyager Vega - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Linux, Apple MacOS X 10.6 or later, Microsoft Windows Vista SP1, Microsoft Windows 7 SP1, Windows 8, Windows 8.1
5-year warranty
USB flash drive
Storage Capacity
64 GB
Interface Type
USB 3.0
Scratch-proof, metal body, key ring loop
Limited warranty - 5 years
24 mm
12.2 mm
4.6 mm
30 g
