Product
Corsair Flash Voyager Slider X1 USB 3.0 256GB
Quicklinx: B33KWS00 Mfr#: CMFSL3X1-256GB
Capacity: 256GB
Interface: USB 3.0
15 in stock
£42.98 ex VAT
£51.57 inc VAT
Flash Voyager Slider X1 has a smart design with a USB connector that retracts for protection when you're not using it. A blue activity LED tells you at a glance if it's transferring data. It's also universally compatible with Windows, Mac OS X and even Linux, with no driver necessary. It supports high-speed USB 3.0 transfers along with full USB 2.0 compatibility, so you can use it with virtually any desktop or notebook.
Corsair Flash Voyager Slider X1 - USB flash drive - 256 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
256 GB
Linux, Apple MacOS X, Microsoft Windows
5 years warranty
USB flash drive
Storage Capacity
256 GB
Compatibility
Non-specific
Read Rate
Up to 130 MB/s
Interface Type
USB 3.0
LED access indicator
Plug and Play
Limited warranty - 5 years
54 mm
23.3 mm
11 mm
9 g
Capacity: 256GB
Interface: USB 3.0
Brand: Corsair
Price Range Ex VAT: 0 - 50
