The Flash Voyager Mini utilizes a cap-less retractable connector plug which easily opens with the flick of the thumb, and its ergonomic rubberized housing makes it easy to connect and disconnect from any computer. This makes it the perfect flash drive for users with busy and active lifestyles. Utilizing the latest Chip-on-Board technology the Flash Voyager Mini is the perfect synergy of size, looks and function.
- CORSAIR Flash Voyager Mini - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 16 GB
- OS Required
- Apple MacOS 9.x or later, Linux Kernel 2.4.2 or later, Microsoft Windows 2000 / ME / XP/ Vista
- 10 years warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- Interface Type
- USB 2.0
- Bootable, shockproof, water resistant, retractable connector, ECC support, Wear Leveling function support
- Plug and Play, VCCI, FCC
- OS Required
- Limited warranty - 10 years
- 0 °C
- 70 °C
- 5 - 95%
