Go Beyond Ordinary USB 3.0 Speed
Standard USB 3.0 flash drives are fast. Flash Voyager GT USB 3.0 is even faster, with data transfer rates of up to two times the speed of standard USB 3.0 drives, and up to eight times the speed of USB 2.0 drives. The portability and convenience of USB drives has always meant putting up with delays while waiting for files to copy, but now they're a thing of the past.
High-Speed USB 2.0 Data Transfer, Too
Chances are that you're still using at least one PC that hasn't yet been upgraded to USB 3.0. Flash Voyager GT has you covered: not only is it fully compatible with USB 2.0, it's also one of the fastest USB 2.0 flash drives on the market. Data transfer across multiple PCs is both fast and worry-free.
And even if you haven't moved to USB 3.0 on your primary system, Flash Voyager GT USB 3.0 is still a great investment. You'll enjoy screaming-fast data transfer rates that push the limits of USB 2.0 performance, and unlock a new speed achievement with your next upgrade.
Durable and Shock-Resistant
The finger-friendly ergonomics of the Flash Voyager GT USB 3.0 will make you want to take it with you everywhere, so reliability is essential.
Corsair's proprietary all-rubber housing is extremely durable, for worry-free transport of your valuable data. And because accidents happen, Flash Voyager GT USB 3.0 is water-resistant.
Unlike traditional storage media, flash drives are solid-state, so they can easily handle the everyday -- and not so everyday -- drops and bumps that come with the territory.
Convenient and Compatible
It works with Microsoft® Windows®, Mac OS X® and even Linux without drivers, and there's no software to install -- just plug it in, and go. If your computer has a USB 2.0 or USB 3.0 connector, you can use Flash Voyager GT USB 3.0.
Backed by Corsair
With a long history of building enthusiast-grade memory products and components, Corsair has built a reputation for quality, compatibility, and performance. Flash Voyager GT is backed by a five-year limited warranty, and if you need help, we're available by phone call, email, or web forum.
- CORSAIR Flash Voyager GT - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 32 GB
- OS Required
- Linux, Apple MacOS X, Microsoft Windows
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- Read Rate
- Up to 190 MB/s
- Write Rate
- Up to 40 MB/s
- Interface Type
- USB 3.0
- Shockproof, water resistant, rubberised
- Plug and Play
- OS Required
- Limited warranty - 5 years
- 8.6 cm
- 2.7 cm
- 22 g
