Corsair Flash Voyager GS USB 3.0 256GB
Quicklinx: B338WS00 Mfr#: CMFVYGS3B-256GB
Flash Voyager GS is a large-capacity, high performance USB 3.0 flash drive in a sleek, scratch-resistant brushed metal enclosure.
  • USB 3.0 speed and USB 2.0 compatibility
    PCs and notebooks with USB 3.0 ports offer transfer speed that's dramatically faster than USB 2.0, but not everybody's there yet. Flash Voyager GS takes advantage of the faster USB 3.0 interface, while providing full USB 2.0 support.
  • Works with virtually any system
    Flash Voyager GS is compatible with Microsoft Windows, Mac OS X and Linux. No drivers are necessary... just plug it in. In short, if your desktop or notebook has a USB 3.0 or 2.0 port, it's compatible with the GS.
  • Key ring compatible
    The loop at the end allows for attaching to most key rings.
CORSAIR Flash Voyager GS - USB flash drive - 256 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
256 GB
Linux, Microsoft Windows, Apple MacOS X or later
5-year warranty
USB flash drive
Storage Capacity
256 GB
Read Rate
Up to 295 MB/s
Write Rate
Up to 170 MB/s
Interface Type
USB 3.0
Metal body
FCC
Limited warranty - 5 years
78.12 mm
26.4 mm
10.8 mm
64 g
