The Corsair Flash Padlock 2 is perfect for transporting and protecting your sensitive business or personal information. With built-in 256-bit hardware data encryption, and access limited by a PIN, you can rest assured your information is safe from unintentional viewing. Built with the same ruggedized rubber housing found on the Corsair Flash Voyager family for durability, your data is protected from the elements as well.
- Secure 256-bit hardware AES encryption.
- User customizable 4-10 digit personal identification number to lock and unlock.
- Built-in hacking detection locks device for 2 minutes after 5 failed attempts .
- Durable rubber, shock-proof housing.
- CORSAIR Flash Padlock 2 - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 16 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- OS Required
- Apple MacOS 9.x or later, Linux Kernel 2.4.2 or later, Microsoft Windows 2000/ME/XP/Vista/7
- 3-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- 256-bit AES
- Interface Type
- USB 2.0
- Shockproof, auto-locking, customizable PIN, ruggedized
- Plug and Play, FCC
- OS Required
- Limited warranty - 3 years
- 68 g
- 0 °C
- 40 °C
- 10 - 90%
