Corsair Crucial DDR4 3000MHz 16GB DIMM Veng LPX Blk
Quicklinx: DX4LWS00 Mfr#: CMK16GX4M1D3000C16
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 3000MHz
Data Integrity: Non-ECC
£48.30 ex VAT
£57.96 inc VAT
Vengeance Low Profile heat spreaders have a reduced height of 1.03". They're designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or any other space-constrained application where you need high-performance memory but standard Vengeance modules might not fit.
  • Great looking, great overclocking memory
    Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
  • Optimized for compatibility with the CPUs and motherboards
    Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
CORSAIR Vengeance LPX - DDR4 - module - 16 GB - DIMM 288-pin - 3000 MHz / PC4-24000 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3000 MHz (PC4-24000)
Latency Timings
CL16 (16-18-18-36)
8 Layers PCB heatspreader, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), Vengeance LPX low profile heatspreader, unbuffered
Voltage
1.35 V
16 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL16 (16-18-18-36)
Non-ECC
Voltage
1.35 V
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15-36 , Tested - 3000 MHz - 1.35 V - CL16 - 16-18-18-36
Colour Category
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 3000MHz
Registered/Buffered: Unbuffered
CAS Latency: CL16
Standard: PC4-24000
Brand: Corsair
