Corsair Carbide SPEC-ALPHA White/Red Mid-Tower ATX Gaming Case
Quicklinx: C0RXWS00 Mfr#: CC-9011083-WW
Corsair Carbide series PC cases have the high-end features you need, and nothing you don’t. Designed to be the foundation of awesome yet approachable gaming PCs, they combine the advanced technology and ergonomic features, lots of room to build and expand, and amazing cooling potential.
CORSAIR Carbide Series SPEC-ALPHA - tower - ATX
System cabinet
Tower
Windowed Side Panel
White, red
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Fan speed controller, front dust filter, rear dust filter
No power supply (ATX)
22 cm x 51.8 cm x 47.4 cm
5.7 kg
Tower
Windowed Side Panel
Max Mainboard Size
ATX
Internal Bays Qty
7
White, red
Cooling System
Front: 120 mm fan x 2 / LED , Top: 120 mm fan mount x 2 , Rear: 120 mm fan x 1
CPU Cooler Max Height
156 mm
Video Card Max Length
380 mm
Power Supply Max Length
190 mm
Expansion Bays
3 (total) / 3 (free) x internal - 3.5" , 4 (total) / 4 (free) x internal - 2.5"
Expansion Slots
7
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
Specification Compliance
ATX
22 cm
51.8 cm
47.4 cm
5.7 kg
