Corsair Carbide Series SPEC-04 Mid Tower Tempered Glass Gaming Case
Quicklinx: D8YCWS00 Mfr#: CC-9011117-WW
£82.89 ex VAT
£99.46 inc VAT
The Carbide Series SPEC-04's angular, hard-edged exterior features bold styling for a remarkable look. The slep, tinted window shows off the roomy interior, which fits up to five 120mm fans and can accommodate ample storage configurations.
  • Stunning style
  • Look sharp, stay cool
  • Ready to build
    The clean, side I/O panel and USB 3.0 port, cable routing cutouts and tie downs, and built-in dust filters combine for you to build a system that's as bold as the SPEC-04's design.
CORSAIR Carbide Series SPEC-04 - tower - ATX
System cabinet
Tower
Windowed Side Panel
Yes, tempered glass
Black, red
I/O Connectors
1 x USB 3.0 , 1 x headphones , 1 x microphone , 1 x USB 2.0
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Front dust filter, cable management holes, supports 120 mm radiator in rear, PSU dust filters, supports 140 mm radiator in front panel
No power supply (ATX)
20.1 cm x 49.2 cm x 43.3 cm
5.27 kg
Tower
Windowed Side Panel
Windowed Side Panel Material
Tempered glass
Max Mainboard Size
ATX
Internal Bays Qty
5
Black, red
Cooling System
Front: 120 mm fan x 1 / LED , Front: 120/140 mm fan mount x 2 , Top: 120 mm fan mount x 2 , Rear: 120 mm fan mount x 1
CPU Cooler Max Height
150 mm
Video Card Max Length
370 mm
Power Supply Max Length
225 mm
Expansion Bays
3 (total) / 3 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7
1 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 1 x USB 2.0
No power supply
Specification Compliance
ATX
20.1 cm
49.2 cm
43.3 cm
5.27 kg
