Carbide Series SPEC-01 is proof that great looks, smart design, and durable construction don't need to be pricy, and that basic doesn't need to be boring. You get aggressive styling, a huge side panel window for admiring your components, and an LED-lit front intake fan that draws cool air directly to your graphics cards.
Inside, there's room for up to five fans, and the four combination hard drive / SSD trays make storage installation and upgrades quick and easy. Cable routing cutouts help you reduce clutter, and the built-in dust filters help protect your components. Up front, the USB 3.0 connector gets you up to speed with the latest high-performance storage devices.
- Tons of fan mounts: Front - 2 x 140/120mm (1 x 120mm LED included), Top - 2 x 120mm, Rear - 120mm
- USB 3.0 front port with internal connector
- Large side panel window
- Cable routing and CPU cooler backplate motherboard cutouts
- Seven PCIe slots with room for long graphics cards up to 420mm long
- Install up to four storage drives, your choice of 3.5" or 2.5", each tray fits both.
- Dust filters for front and PSU intake.
Box Contents
- Carbide Series SPEC-01 Mid Tower Gaming Case
- Accessories box with screws, zip ties, and other mounting hardware.
- Warranty and Support Information
Huge side panel window
The aggressive look of the SPEC-01 makes it look great on the outside, but there's beauty on the inside of a well-built system, too. The large side panel window lets you show it off. -
LED front intake fan, with room for more
The 120 mm front intake fan is bathed in soft LED lighting, and it's oriented to draw cool air directly across your graphics cards. And if you want even more ventilation, you can add a second 120 mm fan or even dual 140 mm fans. -
Flexible cooling potential
Like all Corsair cases, the SPEC-01 is designed for cooling, so you're covered if you're overclocking, running multiple GPUs, or if you just want more airflow. There are mounting points for up to five fans, including dual front 140 mm or 120 mm fans, dual 120 mm fans on top, and a rear 120 mm fan. -
Multiple drive bays
You might not build a system with four hard drives or SSDs, but with SPEC-01, you can if you want. In addition to the two standard 5.25" optical drive bays, there are four built-in 3.5"/2.5" combo drive bays for mechanical hard drives or solid-state drives. -
Easy system builds, maintenance and upgrades
Builds should be easy, no matter what your budget. 3.5" drive installation is tool-free, and you get cable routing holes for neater-looking builds and better airflow. And, there's a CPU cutout to allow for cooling upgrades without removing the motherboard.
- CORSAIR Carbide Series SPEC-01 - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Black
- I/O Connectors
- 1 x USB 3.0 , 1 x headphones , 1 x microphone , 1 x USB 2.0
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Screwless drive bays, front dust filter, CPU cut-out, cable management holes, supports 120 mm radiator in rear, PSU dust filters
- Power Device
- No power supply (ATX)
- 20 cm x 44.7 cm x 42.8 cm
- 4.8 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 2
- Product Material
- Steel
- Black
- Cooling System
- Front: 120 mm fan x 1 / intake / blue LED , Front: 120/140 mm fan mount x 2 , Top: 120 mm fan mount x 2 , Rear: 120 mm fan mount x 1
- CPU Cooler Max Height
- 150 mm
- Video Card Max Length
- 414 mm
- Power Supply Max Length
- 230 mm
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" , 4 (total) / 4 (free) x internal - 2.5" / 3.5" shared
- Expansion Slots
- 7
- 1 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 1 x USB 2.0
- Power Device
- No power supply
- Specification Compliance
- ATX
- 20 cm
- 44.7 cm
- 42.8 cm
- 4.8 kg
- Limited warranty - 2 years
