Corsair Air Series LED high static pressure PC case fans combine efficient high pressure airflow with striking LED lighting. They're custom designed to deliver air directly to high-temperature components with less noise and turbulence than ordinary fans. The custom-molded blades are translucent and have a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series SP fan models are designed for use in restricted spaces. They're ideal for radiator and heatsink use, as well as drive bay intakes and other locations where you're mounting a fan directly adjacent to a heat source. For general purpose case ventilation where you'd like high airflow with minimal excess noise, check out our AF120 and AF140 LED fans.
- Tuned for high pressure air delivery directly to components
- Better performance than standard case fans
- LED-lit translucent, frosted fan blades for a dramatic effect
- Specially designed fan blades and a sleeved bearing system for less vibration, noise and turbulence
High static pressure cooling with led illumination
Air Series LED high static pressure PC case fans combine efficient high pressure airflow with striking LED lighting. They're custom designed to deliver air directly to high-temperature components with less noise and turbulence than ordinary fans. -
Designed for restricted spaces
Air Series fan models are designed for use in restricted spaces. They're ideal for radiator and heatsink use, as well as drive bay intakes and other locations where you're mounting a fan directly adjacent to a heat source.
- CORSAIR Air Series LED SP120 High Static Pressure - case fan
- Product Type
- Case fan
- Package Content
- Mounting screws for case fans
- Green
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 1650 rpm
- Air Flow
- 57.24 cfm
- Noise Level
- 26.4 dBA
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- Green LED x4, custom-molded fan blades
- 140 g
- 2-year warranty
- Product Type
- Case fan
- Package Content
- 140 g
- Green
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 1650 rpm
- Air Flow
- 57.24 cfm
- Air Pressure
- 1.46 mm
- Noise Level
- 26.4 dBA
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- Operation Voltage
- 7 - 12 V
- Rated Current
- 0.26 A
- Mounting Kit
- Included
- Limited warranty: - 2 years
