Corsair Air Series AF140 Quiet Edition (Single Pack)
Quicklinx: 887BWS00 Mfr#: CO-9050009-WW
The Air Series AF140 fan lets you have it all. Eleven ultra-thin, custom-molded blades push ample air volume. Rubber corners dramatically reduce vibration. The advanced hydraulic bearing system is quiet and reliable, and you can customize the look.
AF model is ideal for mounting at the rear or top of your PC case as exhaust fan for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. It works equally well as unrestricted intake fans for areas like side panels or bottom intakes.
CORSAIR Air Series AF140 Quiet Edition - case fan
Case fan
Package Content
Mounting screws for case fans, 3 replaceable colour rings, voltage reduction adapter
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1150 rpm
Air Flow
67.8 cfm
Noise Level
24 dBA
Rated Voltage
12 V
Rubberised corners
240 g
Case fan
Package Content
240 g
Heatsink & Fan
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1150 rpm
Air Flow
67.8 cfm
Air Pressure
0.84 mm
Noise Level
24 dBA
Rated Voltage
12 V
Rated Current
0.1 A
Rubberised corners
Limited warranty: - 2 years
