The Air Series AF120 fans let you have it all. Nine ultra-thin, custom-molded blades push ample air volume. Rubber corners dramatically reduce vibration. The advanced hydraulic bearing system is quiet and reliable, and you can customize the look with the three included colored rings.
AF models performs best in unrestricted spaces with at least 3cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components filling the case with heat. They work equally well for unrestricted intake fans, for areas like side panels or bottom intakes.
- CORSAIR Air Series AF120 Quiet Edition - case fan
- Product Type
- Case fan
- Package Content
- Mounting screws for case fans, 3 replaceable colour rings, voltage reduction adapter
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydraulic bearing
- Rotation Speed
- 1100 rpm
- Air Flow
- 39.9 cfm
- Noise Level
- 21 dBA
- Rated Voltage
- 12 V
- Rubberised corners
- 200 g
- 2-year warranty
- Product Type
- Case fan
- Package Content
- 200 g
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydraulic bearing
- Rotation Speed
- 1100 rpm
- Air Flow
- 39.9 cfm
- Air Pressure
- 0.5 mm
- Noise Level
- 21 dBA
- Rated Voltage
- 12 V
- Rated Current
- 0.08 A
- Limited warranty: - 2 years
