CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-10-9-27, 1.5V for motherboards using AMD, Intel dual channel processors and 2nd Generation Intel Core Processor platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
Key Features
- 8GB (2x4GB) DDR3 for AMD, Intel Dual processors and 2nd Generation Intel Core Processor platforms
- 1866MHz
- 9-10-9-27 latency
- Vengeance Red heat spreader for styling and performance
- Intel XMP (Extreme Memory Profile) Support
- Limited Lifetime Warranty
Specification
- Density: 8GB (2x4GB Module)
- Speed: 1866MHz
- Timing: 9-10-9-27
- Type: DDR3
- Format: DIMM
- Pin Out: 240 Pin
- Voltage: 1.5V
Great looking, great overclocking memory
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig. -
Optimized for compatibility with the CPUs and motherboards
Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
- CORSAIR Vengeance - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1866 MHz / PC3-15000 - unbuffered
- Product Type
- Memory kit
- Capacity
- 8 GB: 2 x 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1866 MHz (PC3-15000)
- Latency Timings
- CL9 (9-10-9-27)
- Intel Extreme Memory Profiles (XMP), Vengeance heatspreader, unbuffered
- Voltage
- 1.5 V
- Limited lifetime warranty
- Capacity
- 8 GB: 2 x 4 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL9 (9-10-9-27)
- Non-ECC
- Voltage
- 1.5 V
- Compatible Slots
- 2 x memory - DIMM 240-pin
