Corsair 8GB (2x4GB) DDR3 1866Mhz CL9 Vengeance Red Performance Desktop Memory Kit
Quicklinx: 7JJQWS00 Mfr#: CMZ8GX3M2A1866C9R
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-10-9-27, 1.5V for motherboards using AMD, Intel dual channel processors and 2nd Generation Intel Core Processor platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
Key Features
  • 8GB (2x4GB) DDR3 for AMD, Intel Dual processors and 2nd Generation Intel Core Processor platforms
  • 1866MHz
  • 9-10-9-27 latency
  • Vengeance Red heat spreader for styling and performance
  • Intel XMP (Extreme Memory Profile) Support
  • Limited Lifetime Warranty
Specification
  • Density: 8GB (2x4GB Module)
  • Speed: 1866MHz
  • Timing: 9-10-9-27
  • Type: DDR3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.5V
  • Great looking, great overclocking memory
    Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
  • Optimized for compatibility with the CPUs and motherboards
    Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
CORSAIR Vengeance - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1866 MHz / PC3-15000 - unbuffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-15000)
Latency Timings
CL9 (9-10-9-27)
Intel Extreme Memory Profiles (XMP), Vengeance heatspreader, unbuffered
Voltage
1.5 V
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-10-9-27)
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Resources
The following resources are available for the Corsair 8GB (2x4GB) DDR3 1866Mhz CL9 Vengeance Red Performance Desktop Memory Kit
