Corsair 8GB (2x4GB) DDR3 1333Mhz CL9 Value Select  Desktop Memory Kit
Quicklinx: 7JGMWS00 Mfr#: CMV8GX3M2A1333C9
Corsair built its reputation on performance memory that shines in the most demanding computing situations: extreme gaming and high-transaction processing environments. But not all computers are put to such extreme usage. So we brought the same reliability, testing and Corsair quality to a line of memory designed to support standard computing situations such as popular office applications. Now it's one of our most popular memory lines. Backed with a lifetime warranty, it is memory you can rely on.
  • 8GB Kit (2x4GB)
  • DDR3 1333MHz DIMM
  • 333MHz
  • 9-9-9-24 latency
  • 10 Year Warranty
  • Density: 8GB Kit (2x4GB)
  • Speed: 1333MHz
  • Timing: 9-9-9-24
  • Type: DDR3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.5V
  • Warranty: 10 Years
CORSAIR Value Select - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9 (9-9-9-24)
Unbuffered
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Unbuffered
Compatible Slots
2 x memory - DIMM 240-pin
