Corsair Vengeance Pro Series memory modules are designed for overclocking on the latest 3rd and 4th generation Intel® Core™ platforms, with eight-layer PCBs and ICs specially selected for performance potential. The aluminum heat spreaders provide superior temperature management and have the aggressive look you want in your gaming rig. XMP 1.3 profiles allow for automatic, reliable overclocking.
They're available in multiple colours to let you match your Vengeance Pro memory to your system's color scheme. As a bonus, they're priced to deliver class-leading value, so you'll have more room left in your system build budget.
Great looking, great overclocking memory
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig. -
Optimized for compatibility with the CPUs and motherboards
Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
- CORSAIR Vengeance Pro Series - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 2133 MHz / PC3-17066 - unbuffered
- Product Type
- Memory kit
- Capacity
- 8 GB: 2 x 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC3-17066)
- Latency Timings
- CL9 (9-11-11-31)
- Aluminium heatsink, dual channel, Vengeance heatspreader, Intel Extreme Memory Profiles (XMP 1.3), unbuffered
- Voltage
- 1.65 V
- Limited lifetime warranty
- Capacity
- 8 GB: 2 x 4 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL9 (9-11-11-31)
- Non-ECC
- Voltage
- 1.65 V
- Compatible Slots
- 2 x memory - DIMM 240-pin
