Corsair 8GB (1x8GB) DDR3 1600Mhz CL10 Vengeance SODIMM  Performance Notebook Memory Module
Quicklinx: 82MVWS00 Mfr#: CMSX8GX3M1A1600C10
CORSAIR high performance Vengeance SODIMM memory module, 8GB (1x8GB) 1600MHz 10-10-10-27, 1.5V, allows you to automatically boost performance of your without bios reconfiguration. Slim and attractive design to ensure physical compatibility with all 2nd Generation Intel Core™ i5 and i7 notebooks. Each module is built using carefully selected DRAM to allow excellent stability and is backed by Corsair's limited lifetime warranty.
Key Features
  • 8GB (1x8GB) DDR3 SODIMM for 2nd Generation Intel Core™ i5 and i7 notebooks.
  • 1600MHz
  • 10-10-10-27 latency
  • 1.5V
  • Auto-overclocking (no bios configuration required)
  • Limited Lifetime Warranty
  • Density: 8GB (1x8GB Module)
  • Speed: 1600MHz
  • Timing: 10-10-10-27
  • Type: DDR3
  • Format: SODIMM
  • Pin Out: 204 Pin
  • Voltage: 1.5V
  • Note: if two modules are used both should be the same speed and timings
  • Great looking, great overclocking memory
    Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
  • Optimized for compatibility with the CPUs and motherboards
    Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
CORSAIR Vengeance - DDR3 - module - 8 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
8 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL10 (10-10-10-27)
Unbuffered
Voltage
1.5 V
8 GB
Upgrade Type
Generic
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL10 (10-10-10-27)
Non-ECC
Unbuffered
Voltage
1.5 V
Compatible Slots
1 x memory - SO-DIMM 204-pin
