Compatible with 4th generation Intel® Core™ series processors
A new more efficient version of the awarding winning AX Series power supplies
Platinum Efficiency and Silent Fanless Mode
The Corsair AX860 power supply runs quieter, generates minimal excess heat and it's earned the 80 Plus® Platinum seal of approval, your guarantee that you're making the right choice for smart, efficient power delivery. Because the AX860 is so efficient it operates without the fan even spinning at low and moderate loads.
A Fully Modular Cabling System
All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow.
Built with the Best
Built with High-quality 105C capacitors and upgraded components the AX860 is rated to run at 50°C and provide rock solid power throughout its seven year warranty.
Product Features
- The latest ATX12V v2.31 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems.
- Silent at low to moderate load due to high efficiency and zero RPM fanless mode. Ultra quiet at high loads with 120mm dual-ball bearing fan.
- 80PLUS Platinum certified, delivering over 92% energy efficiency at real world load conditions.
- Active Power Factor Correction (PFC) with PF value of 0.99.
- Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
- A dedicated single +12V rail offers maximum compatibility with the latest components.
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components.
- High-quality Japanese capacitors provide uncompromised performance and reliability.
- The completely modular cable system allows you to use only the cables you need. Power supply upgrade and replacement is easy, as the cables only need to be disconnected at the power supply.
- Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer's chassis.
- A Seven year warranty and lifetime access to Corsair's legendary technical support and customer service.
- Safety Approvals: cTUVs, TUV, CB, CE, FCC, CCC, RCM, GOST-R, KC, IRAM, BSMI.
Less heat generation and lower operating costs
Excess heat means wasted energy. 80 Plus platinum certified efficiency means less waste. -
Zero RPM mode for silent operation at low loads
The fan doesn't even spin when your system is idle or doing basic work like surfing the web or running office applications. -
Easy installation
The fully modular cable set lets you use only the cables you need. You can install the AX Series first and then add cables one-by-one without having to deal with the dreaded "cable octopus". -
Stable, reliable power output
High-quality components and careful design help ensure maximum protection for your PC's components. -
Flexible and compatible
AX series comes with long cables for large cases, and lots of connectors for just about any hardware configuration. -
80 Plus platinum efficiency
AX860 delivers up to 92% energy efficiency under real-world load conditions. Better efficiency means lower energy usage, less excess heat, and lower operating costs. Since less heat is generated, the fan doesn't have to work as hard, so there's less noise, too. It's a great choice for smart, efficient power delivery. -
Advanced temperature-controlled fan with Zero RPM mode
The fan doesn't even spin at low loads. And when you're pushing it hard, the double ball bearing 140mm fan adjusts its speed according to temperature, so it only works as hard as it needs to. -
Fully modular connection system with low-profile cables
All of the power cables have connectors on both ends, with nothing hard-wired to the PSU. This makes for easier installs (you don't need to deal with an octopus of cables while you're putting in the power supply), and you can add cables one-by-one, using only the cables you need. The result is a cleaner-looking build, with better airflow. -
Clean, stable power delivery
High-quality capacitors, a dedicated single +12 V rail and a PF value of 0.99 give you reliable power output with extremely low ripple and noise. Over-voltage, under-voltage, over-current, and short circuit protection provide maximum safety for your critical system components. And, AX860 is engineered to meet maximum power output at a server-grade 50° C temperature rating.
- CORSAIR AX860 - power supply - 860 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.31/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Platinum
- 3.29 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 860 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 71.6 A , -12V - 0.8 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 8 x 4 PIN internal power , 12 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 120 mm fan
- Included Accessories
- Cable ties, mounting kit, cable bag
- 15 cm x 16 cm x 8.6 cm
- 7 years warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Input Voltage Range
- AC 90 - 264 V
- Frequency Required
- 50/60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 860 Watt
- Output Current
- 80 PLUS Platinum
- Cables Included
- Power cable kit
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Over current protection, over voltage protection, undervoltage protection, short-circuit protection, single 12V rail, dual ball bearing cooling fan, fully modular
- FCC Class B certified, TUV, C-Tick, BSMI, CB, CCC, IRAM, GOST-R, cTUVus, KC
- Limited warranty - 7 years
- 15 cm
- 16 cm
- 8.6 cm
- 3.29 kg
- Shipping Width
- 39.1 cm
- Shipping Depth
- 22.5 cm
- Shipping Height
- 15.1 cm
- Shipping Weight
- 4 kg
