Corsair 760W AX760i 80PLUS Platinum High Performance Digital PSU
Quicklinx: 8D4RWS00 Mfr#: CP-9020036-UK
The AXi series PSU is the desktop PC power supply to use digital (DSP) control and Corsair Link to bring you an unprecedented level of monitoring and performance customization. The DSP in the AX760i makes on-the-fly adjustments for incredibly tight voltage regulation, 80 PLUS Platinum Efficiency, and clean, stable power.
AX760i's extreme efficiency earns it coveted 80 PLUS Platinum certification. Less wasted power means minimal excess heat. This can reduce the strain on your other components, and it can save you money over the long run in the form of lower power bills.
  • Corsair AXi Digital ATX PSU: complete digital control
  • Stable and reliable power delivery
    DSP-controlled, real-time voltage regulation helps ensure that your valuable components receive clean, stable power.
  • Less heat and lower operating cost
  • Quiet operation at low loads
    Super-high efficiency has another benefit: silence. The thermally-controlled fan doesn't even spin at low loads. It's ideal if you're building a quiet PC or you just want to reduce the amount of ambient noise in your life.
  • Easy installation and cable routing, with better airflow
    The fully modular cable set allows you to use only the cables you need, and the flat design makes cable routing much easier in tight spaces. You get a clean-looking system build with cables out of the airflow path for efficient space usage that's energy efficient as well.
CORSAIR AX760i - power supply - 760 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31/ EPS12V 2.92
80 PLUS Certification
80 PLUS Platinum
3.29 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
760 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 63.3 A , -12V - 0.8 A , +5VSB - 3 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 8 x 4 PIN internal power , 12 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
Modular Cable Management
Cooling System
120 mm fan
Cable ties, mounting kit, cable bag
15 cm x 16 cm x 8.6 cm
10 years warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
50/60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
760 Watt
Output Current
80 PLUS Platinum
Power cable kit
MTBF
100,000 hours
Cooling System
120 mm fan
Corsair Link, over current protection, over voltage protection, undervoltage protection, short-circuit protection, single 12V rail, dual ball bearing cooling fan, Zero RPM fan mode, fully modular
FCC Class B certified, TUV, C-Tick, CB, CCC, cTUVus
Limited warranty - 10 years
15 cm
16 cm
8.6 cm
3.29 kg
Shipping Width
39.1 cm
Shipping Depth
22.5 cm
Shipping Height
15.1 cm
Shipping Weight
4 kg
Resources
The following resources are available for the Corsair 760W AX760i 80PLUS Platinum High Performance Digital PSU
