Corsair 60GB Force LS v2 Series 2.5" SATA 6Gbps SSD
Quicklinx: B7S7WS00 Mfr#: CSSD-F60GBLSB
Force Series LS solid-state drives offer flexible, cost-effective SATA 3 solid-state storage for general-purpose desktop and notebook PCs.
  • Fast performance
    Games, applications and files load faster, while your system is more responsive.
  • Flexible use
    2.5" form factor for your notebook or netbook needs, or use with included 3.5" bracket for your desktop computer.
  • Silent operation
    No moving parts mean zero noise and high reliability.
  • Low power
    Extend battery life for notebook and netbook users.
  • Reliable
    Over 1,000,000 hours mean time between failures.
CORSAIR Force Series LS - SSD - 60 GB - SATA 6Gb/s
Solid state drive - internal
60 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant, TRIM support, S.M.A.R.T.
69.85 mm x 100.1 mm x 7 mm
50 g
3-year warranty
60 GB
2.5"
SATA 6Gb/s
69.85 mm
100.1 mm
7 mm
50 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 440 MBps (write)
Maximum 4KB Random Write
23000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
FCC
Limited warranty - 3 years
70 °C
0 - 90%
