Corsair 550W VS550 VS Series ATX Power Supply Unit
Quicklinx: B3LCWS00 Mfr#: CP-9020097-UK
VS550: the entry-level 240V power supply with high-end features
The Corsair VS550 is a great choice if you're building a home or office system with lower power demands, but you still demand the compatibility and reliability that Corsair is known for.
Real power
The VS550 delivers a guaranteed 550 Watts of continuous power. With 0.99 Active Power Factor Correction, you get the peace of mind from knowing that your components are protected from uneven power delivery. And, a dedicated single +12V rail saves you from the hassle of balancing your components across multiple power cables
Low noise, high efficiency
The 120mm fan is thermally controlled, so it only spins at maximum speed when it's pushed hard - and even at full load, it's pretty quiet. Smart design features like this are why VS550 offers up to 85% efficiency. Your PC system will generate less heat, and you'll enjoy lower energy bills
Sophisticated design
The black powder-coated enclosure and the black-sleeved cables give any system a polished look. You're building a PC, not a battleship, and with the VS550 you can avoid that look of unpainted steel that you'll find on so many entry-level power supplies.
Reliability you can count on
VS550 is backed with a three-year warranty, and you get lifetime access to Corsair's legendary technical support and customer service.
Package contents
VS Series power supply
AC power cord
Cable ties
Mounting screws
Compatibility
Conforms to ATX12V v2.31 standard, and is backward compatible with the ATX12V 2.2 and ATX12V 2.01 standards
A dedicated single +12V rail offers maximum compatibility with the latest components
Active Power Factor Correction (PFC) with PF value of 0.99
AC input from 200~240VAV
Over-voltage, under-voltage, over-current, and short circuit protection provide maximum safety for your critical system components
High-quality capacitors provide uncompromised performance and reliability
A three year warranty and lifetime access to Corsair's legendary technical support and customer service
Safety Approvals: cTUVus, CE, CB, FCC Class B, TÜV, CCC, C-tick
  • Real power
    The VS550 delivers a guaranteed 550 Watts of continuous power. With 0.99 Active Power Factor Correction, you get the peace of mind from knowing that your components are protected from uneven power delivery. And, a dedicated single +12V rail saves you from the hassle of balancing your components across multiple power cables.
  • Low noise, high efficiency
    The 120mm fan is thermally controlled, so it only spins at maximum speed when it's pushed hard - and even at full load, it's pretty quiet. Smart design features like this are why VS550 offers up to 85% efficiency. Your PC system will generate less heat, and you'll enjoy lower energy bills.
  • Sophisticated design
CORSAIR VS Series VS550 - power supply - 550 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V
80 PLUS Certification
80 PLUS
1.5 kg
United Kingdom
Input Voltage
AC 200-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output Current
+3.3V - 18 A , +5V - 18 A , +12V - 42 A , -12V - 0.3 A , +5VSB - 2.5 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V , 4 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 2 x 4 PIN mini-power connector
Cooling System
120 mm fan
Cable ties, mounting kit
Black powder coat
15 cm x 14 cm x 8.6 cm
3-year warranty
ATX12V 2.3/ EPS12V
PSU Form Factor
ATX
Black powder coat
United Kingdom
Input Voltage
AC 200-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Max Electric Current
5 A
Power Capacity
550 Watt
Output Current
Efficiency
85%
80 PLUS
MTBF
100,000 hours
Cooling System
120 mm fan
Sleeved cables, over current protection, over voltage protection, undervoltage protection, short-circuit protection, single 12V rail, temperature controlled fan, non-modular
FCC Class B certified, TUV, C-Tick, CB, CCC, cTUVus
Limited warranty - 3 years
15 cm
14 cm
8.6 cm
1.5 kg
Shipping Width
26 cm
Shipping Depth
18 cm
Shipping Height
9.6 cm
Shipping Weight
1.64 kg
