Corsair 512MB (1x512MB) DDR1 400Mhz CL3 Value Select SODIMM  200 Pin Notebook Memory Module
Quicklinx: 3JXWWS00 Mfr#: VS512SDS400
Corsair memory is specifically designed for rock-solid performance in the most demanding of applications. Data lines are specifically designed for noise immunity; clock lines are optimized for minimum skew. Corsair has many years of experience in qualifying high-performance notebook memory, and has developed a knowledge base and track record, which is among the best in the industry. Corsair also has strict standards for product qualification; any changes in design, bill-of-materials, and/or supplier, must be re-qualified prior to shipment to end customers. These high standards have resulted in a very robust product, with extremely few failures, returns, or compatibility problems.
CORSAIR Value Select - DDR - module - 512 MB - SO-DIMM 200-pin - 400 MHz / PC3200 - unbuffered
Memory module
512 MB
Memory Type
DDR SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
400 MHz (PC3200)
Unbuffered
512 MB
Upgrade Type
Generic
DRAM memory module
DDR SDRAM
SO-DIMM 200-pin
Speed
400 MHz (PC3200)
Non-ECC
Unbuffered
Module Configuration
64 x 64
Compatible Slots
1 x memory - SO-DIMM 200-pin
