Corsair 4GB (2x2GB) DDR2 800Mhz CL5 Value Select  240 Pin Desktop Memory Kit
Quicklinx: 5KBSWS00 Mfr#: VS4GBKIT800D2
The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
CORSAIR Value Select - DDR2 - kit - 4 GB: 2 x 2 GB - DIMM 240-pin - 800 MHz / PC2-6400 - unbuffered
Memory kit
4 GB: 2 x 2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL5 (5-5-5-18)
Unbuffered
Voltage
1.8 V
4 GB: 2 x 2 GB
Upgrade Type
Generic
DRAM memory kit
DDR2 SDRAM
DIMM 240-pin
Speed
800 MHz (PC2-6400)
Latency Timings
CL5 (5-5-5-18)
Non-ECC
Unbuffered
Voltage
1.8 V
Compatible Slots
2 x memory - DIMM 240-pin
