The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
- CORSAIR Value Select - DDR2 - kit - 4 GB: 2 x 2 GB - DIMM 240-pin - 800 MHz / PC2-6400 - unbuffered
- Product Type
- Memory kit
- Capacity
- 4 GB: 2 x 2 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 800 MHz (PC2-6400)
- Latency Timings
- CL5 (5-5-5-18)
- Unbuffered
- Voltage
- 1.8 V
- Limited lifetime warranty
- Capacity
- 4 GB: 2 x 2 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL5 (5-5-5-18)
- Non-ECC
- Unbuffered
- Voltage
- 1.8 V
- Compatible Slots
- 2 x memory - DIMM 240-pin
