Corsair 4GB (1x4GB) DDR3 1333Mhz CL9 Value Select  Desktop Memory Module
Quicklinx: 73DKWS00 Mfr#: CMV4GX3M1A1333C9
Type: DDR3 SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 1333MHz
Data Integrity: Non-ECC
£15.66 ex VAT
£18.79 inc VAT
Corsair Memory 4GB Single Module 1333MHz CL 9-9-9-24 1.5V DDR3 DIMM for Intel and AMD platform system builds and upgrades. Corsair built its reputation on performance memory that shines in the most demanding computing situations: extreme gaming and high-transaction processing environments. But not all computers are put to such extreme usage. So we brought the same reliability, testing and Corsair quality to a line of memory designed to support standard computing situations such as popular office applications. Now it's one of our most popular memory lines. Backed with a lifetime warranty, it is memory you can rely on
  • Density: 4GB
  • Speed: 1333MHz
  • Timing: 9-9-9-24
  • Type: DDR3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.5
  • Single 4GB Module
  • DDR3
  • 1333MHz performance Latency of 9-9-9-24 to maximize system performance
  • 100% Guaranteed compatibility with all Intel and AMD DDR3 platforms
  • Limited Lifetime Warranty
  • Reliable capacity
    This memory kit provides a total of 4 GB storage capacity, making it suitable for various PC applications and enhancing overall performance.
  • Efficient speed
    Operating at a speed of 1333 MHz, the memory ensures efficient data processing and improves system responsiveness across multiple tasks.
  • Stable performance
    With a CAS latency of CL9, this memory kit balances speed and stability, allowing for smooth operation during computing activities.
  • Standard compatibility
    Designed for user convenience, it fits into DIMM 240-pin slots, ensuring compatibility with a wide range of PC motherboards.
  • Solid construction
    The non-ECC design offers a straightforward approach to memory integrity, facilitating stable operations for both everyday computing and demanding tasks.
CORSAIR Value Select - DDR3 - kit - 4 GB: 2 x 2 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
Memory kit
4 GB: 2 x 2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9 (9-9-9-24)
Unbuffered
4 GB: 2 x 2 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Unbuffered
Type: DDR3 SDRAM
Capacity: 4GB
Speed: 1333MHz
Registered/Buffered: Unbuffered
CAS Latency: CL9
Standard: PC3-10600
Brand: Corsair
Stock Status: While stocks last
Stock Status: Clearance
