Corsair 4GB (1x4GB) DDR3 1066Mhz  Value Select SODIMM  204 Pin Notebook Memory Module
Quicklinx: 67NWWS00 Mfr#: CM3X4GSD1066
Designed for current generation notebooks and mini-PCs, Corsair's high density SODIMMs allow users to maximize memory bandwidth and minimize performance bottleneck to deliver superior user experience.
CORSAIR - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1066 MHz / PC3-8500 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1066 MHz (PC3-8500)
Latency Timings
CL7 (7-7-7-20)
Unbuffered
4 GB
Upgrade Type
Generic
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
1066 MHz (PC3-8500)
Latency Timings
CL7 (7-7-7-20)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 204-pin
