The Dominator family of memory represents the ultimate in performance technology engineering from Corsair. The Dominator is designed to have the highest performing IC maximum over-clocking capability and efficient DHX cooling - all the while being stable and reliable.
Very few components make it into the Dominator family. Corsair performs rigorous testing and screening on all components to select only the best for the Dominator modules. The tests check for high frequency and/or low latency capabilities for each IC. Then, they are thoroughly tested for maximum interoperability and reliability as a united group to meet the stringent design criteria demanded by performance computing and gaming users.
- CORSAIR Dominator Platinum - DDR4 - kit - 32 GB: 4 x 8 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - unbuffered
- Product Type
- Memory kit
- Capacity
- 32 GB: 4 x 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2666 MHz (PC4-21300)
- Latency Timings
- CL15 (15-17-17-35)
- Temperature monitoring, Dual-path Heat Xchange (DHX), aluminium heat spreader, activity LED's, dual channel, quad channel, Ultra Low Voltage, Corsair Link connector, Corsair Dominator Platinum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
- Voltage
- 1.2 V
- Limited lifetime warranty
- Capacity
- 32 GB: 4 x 8 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- Non-ECC
- Voltage
- 1.2 V
