The TWIN2X2048-6400 is a 2 GByte matched pair of DDR2 SDRAM DIMMs. This part delivers outstanding performance in the latest generation of DDR2-based motherboards. It has been tested extensively in multiple DDR2 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 800MHz at the low latencies of 5-5-5-12-18. This module is also available in a single module part.
- CORSAIR XMS2 Xtreme Performance TwinX Matched - DDR2 - kit - 2 GB: 2 x 1 GB - DIMM 240-pin - 800 MHz / PC2-6400 - unbuffered
- Product Type
- Memory kit
- Capacity
- 2 GB: 2 x 1 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 800 MHz (PC2-6400)
- Latency Timings
- CL5 (5-5-5-18)
- Unbuffered
- Voltage
- 1.9 V
- Limited lifetime warranty
- Capacity
- 2 GB: 2 x 1 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL5 (5-5-5-18)
- Non-ECC
- Unbuffered
- Chips Organization
- 64 x 8
- Voltage
- 1.9 V
- Compatible Slots
- 2 x memory - DIMM 240-pin
Customer reviews
Write a review for the Corsair 2GB (2x1GB) DDR3 6400 CL5 XMS2 Heatspreader Desktop Memory Kit here!
Brilliant Overclockable Memory
Reviewed by Chobbit. Review Posted 19/03/2009
Okay so this is my second review, had the memory for 3 months now without a single problem. I got brave and decided to do some overclocking and they are brilliant at that. Both sticks are now running at 4-4-4-12 and i've been able to increase their FSB's from 400 (800FSB) to 450 (900FSB) stably with no problems. -Note- i've left my Memory voltages set to Auto, so if your not able to I don't know what voltage you would need to set to achieve this manually. But yeah amazing overclockable Memory
- Overall
- Ease of use
- Value for money
Great
Reviewed by Chobbit. Review Posted 06/01/2009
Bargain, Definetly Memory worth buying.
Only had the memory a short time so not sure about reliability yet, Easy to install though, looking else where people have claimed it will do timings of 4-4-4-12 by increasing voltage to 2.353 but i'm not risking it and set it manually in the Bios to 5-5-5-12 which runs stable and does the job.
The memory alone has allowed me run Far Cry 2 fine on very high 1280x1024 settings, instead of on normal 1024x768 settings i had to resort too previously.
- Overall
- Ease of use
- Value for money
GREAT
Reviewed by Anonymous Review Posted 25/11/2008
Ive had this 2GB kit for 5 months now and ive just bought a second 2gb kit which should arrive tomorrow.
Ive had great performance out of the 2gb ive been using just what i expected from corsiar xms ram
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
