Corsair Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop systems.
- CORSAIR Value Select - DDR2 - kit - 2 GB: 2 x 1 GB - DIMM 240-pin - 533 MHz / PC2-4200 - unbuffered
- Product Type
- Memory kit
- Capacity
- 2 GB: 2 x 1 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 533 MHz (PC2-4200)
- Unbuffered
- Voltage
- 1.8 V
- Limited lifetime warranty
- Designed For
- ABIT AL8, AW8, LP-80, 81, NI8; AOpen i915; ASUS P5AD2, P5LD2, P5ND2, P5WD2; Biostar N4SIE, P4TAW; Chaintech V925, Z925; ECS 915, PF21, PF4; EPoX EP-5EGA+, 5LWA+, 5NVA+; FIC Crusader II CS2; Foxconn 915A01, 915M03, 925A01; Gigabyte GA-8I945, 8I955; MSI 945, 955, P4N; SUPERMICRO SUPER P8SCi
- Capacity
- 2 GB: 2 x 1 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Non-ECC
- Unbuffered
- Module Configuration
- 128 x 64
- Voltage
- 1.8 V
- Compatible Slots
- 2 x memory - DIMM 240-pin
- Designed For
- ABIT AA8 DuraMAX, AA8-3rd Eye, AA8XE, AL8, AW8, AW8-MAX, Fatal1ty AA8XE, LP-80, LP-81, NI8 SLI , AOpen i915Ga-EFRII, i915Pa-EFRII , ASUS P4GD1, P5AD2 Deluxe, P5AD2 Premium, P5AD2-E Deluxe, P5AD2-E Premium, P5GD2, P5GD2 Deluxe, P5GD2 Premium, P5GDC Deluxe, P5GDC-V Deluxe, P5LD2 AiLife Series, P5ND2-SLI Deluxe, P5WD2 AiLife Series, P5WD2 Premium AiLife Series , Biostar N4SIE-A7, P4TAW Extreme, P4TGP 775 , Chaintech V925X ZENITH VE, Z925X ZENITH , DFI 925X-T2, UT 915P-T12 , ECS 915G-A, 915P-A, PF21 Extreme, PF4 Extreme , EPoX EP-5EGA+, EP-5LWA+, EP-5NVA+ SLI , FIC P4M-915GD1, P4M-915GD2, P4M-915PD1, P4M-915PD2 , FIC Crusader II CS2-P4M915GD1, CS2-P4M915GD2 , Foxconn 915A01-P-8EKRS2, 915M03-G-8EKRS2, 925A01-8EKRS2 , Gigabyte GA-8AENXP-D, GA-8ANXP-D, GA-8GPNXP Duo, GA-8I915P Duo Pro, GA-8I915P Duo Pro-A, GA-8I915P Duo-A, GA-8I915P-MF, GA-8I945G, GA-8I945G PRO, GA-8I945GMF, GA-8I945P Dual Graphic, GA-8I945P PRO, GA-8I945P-G, GA-8I955X PRO, GA-8I955X Royal , Intel Desktop Board D915GEV, D915GUX, D915PBL, D915PCM, D915PCY, D925XBC, D925XCV, D925XEBC2, D925XECV2 , MSI 915G Combo-FR, 915G Neo2 Platinum, 915P Combo-FR, 915P Neo2 Platinum, 915P Neo2-FR, 925X Neo Platinum-54g, 925XE Neo Platinum, 945P Neo-F, 945P Platinum, 955X Platinum, P4N Diamond , Soltek SL-915GPRO-FGR , SUPERMICRO SUPER P8SAA, P8SCi , Tyan Tomcat i925X S5130
Customer reviews
Write a review for the Corsair 2GB (2x1GB) DDR2 533Mhz CL4 Value Select 240 Pin Desktop Memory Kit here!
No problems here
Reviewed by Michael. Review Posted 04/08/2009
We bought 20 packs of this memory a few weeks ago, delivery was prompt, we've now fitted all 20 packs (40 sticks) of RAM into 20 DELL GX280's and not had a single issue with any of them. Good quality ram!
Overall
Ease of use
Value for money
Faulty
Reviewed by Chris. Review Posted 06/02/2008
I bought this along with other parts, One of the stcicks now has stopped workin after a few weeks, and you cant just send one back, which means i will be without a working pc for at least two weeks, i think this is the wrong way about dealing with customers especially after spending so much with this company, I am dissapointed.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
