Corsair 2GB (2x1GB) DDR1 400Mhz CL3 Value Select  184 Pin Desktop Memory Kit
Customer rating: 5.0* (Write a review)
Quicklinx: 3PCNWS00 Mfr#: VS2GBKIT400C3
Corsair Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop systems.
CORSAIR Value Select - DDR - kit - 2 GB: 2 x 1 GB - DIMM 184-PIN - 400 MHz / PC3200 - unbuffered
Memory kit
2 GB: 2 x 1 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
400 MHz (PC3200)
Latency Timings
CL3
Unbuffered
2 GB: 2 x 1 GB
Upgrade Type
Generic
DRAM memory kit
DDR SDRAM
DIMM 184-PIN
Speed
400 MHz (PC3200)
Latency Timings
CL3
Non-ECC
Unbuffered
Module Configuration
128 x 64
Compatible Slots
2 x memory - DIMM 184-PIN
Customer reviews
Write a review for the Corsair 2GB (2x1GB) DDR1 400Mhz CL3 Value Select 184 Pin Desktop Memory Kit here!
Faultless
Reviewed by Qbert. Review Posted 20/02/2007
Installed no problems. Works well along side exsisting ram. now have 2.5GB. Dabs service great as usual. On the door the following day. Also £10 with email coupon.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Bad Stick
Reviewed by Neil. Review Posted 02/03/2007
Well after a week, one of the sticks started to playup. But these things happen and the dabs return process is as painless and easy is ever. New sticks work like a dream.
  • Overall 5*
  • Ease of use 5*
Simple
Reviewed by Anonymous Review Posted 07/08/2008
Awesome. 2 days, arrived, in, working. fantastic value.
  • Overall 5*
  • Ease of use 5*
Read all 6 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
