CMSO2GX3M1A1333C9 is Corsair's mainstream SODIMM memory solution for DDR3 laptops. Designed for notebooks, mini-PCs and netbooks, Corsair's high density SODIMMs allow users to maximize memory bandwidth and minimize performance bottleneck to deliver superior user experience.
- CORSAIR - DDR3 - module - 2 GB - SO-DIMM 204-pin - 1333 MHz / PC3-10600 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR3 SDRAM - SO-DIMM 204-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1333 MHz (PC3-10600)
- Latency Timings
- CL9 (9-9-9-24)
- Unbuffered
- Voltage
- 1.5 V
- Limited lifetime warranty
- Capacity
- 2 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Latency Timings
- CL9 (9-9-9-24)
- Non-ECC
- Unbuffered
- Voltage
- 1.5 V
- Compatible Slots
- 1 x memory - SO-DIMM 204-pin
