The Value Select line provides quality tested desktop and laptop memory at competitive prices.
- CORSAIR Value Select - DDR2 - module - 2 GB - SO-DIMM 200-pin - 667 MHz / PC2-5300 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR2 SDRAM - SO-DIMM 200-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 667 MHz (PC2-5300)
- Unbuffered
- Limited lifetime warranty
- Capacity
- 2 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- SO-DIMM 200-pin
- Speed
- Non-ECC
- Unbuffered
- Module Configuration
- 256 x 64
- Compatible Slots
- 1 x memory - SO-DIMM 200-pin
Customer reviews
Write a review for the Corsair 2GB (1x2GB) DDR2 667Mhz CL5 Value Select SODIMM 200 Pin Notebook Memory Module here!
Excellent memory
Reviewed by Jonathan. Review Posted 15/02/2008
Don't be put off by the value attached to this, I bought this for my MacBook and its runs like a champ, no problems. My Macbook is one of the Pre Santa Rosa models as well so it can only see 3GB instead of 4. This doesn't matter so if there are any Mac users out there, this is the stuff to buy, especially at this price.
Overall
Ease of use
Value for money
Cheep at the price
Reviewed by retrodome. Review Posted 18/01/2008
Great value - max'ed out my EEE no issues (turned pagefile off)
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
