USB 3.0 speed. USB 2.0 compatibility. Flash Voyager durability.
As fast as USB flash drives are, copying files always seems to take a little longer than you'd like. The advent of the USB 3.0 interface puts an end to that. You can move files back and forth in a fraction of the time it takes with standard USB 2.0 flash drives, and the proprietary water-resistant rubber housing helps keep those files safe.
USB 2.0 compatible
Of course, Flash Voyager USB 3.0 is backward compatible with USB 2.0. Even if you haven't yet upgraded your PC to USB 3.0, it's still a great choice for convenient, reliable portable file management, and the additional performance will be ready when your PC is.
Durable and shock-resistant
The finger-friendly ergonomics of the Flash Voyager USB 3.0 will make it the USB flash drive that you'll want to take with you everywhere. Reliability is essential.
Corsair's proprietary all-rubber housing is extremely durable, for worry-free transport of your valuable data. And because accidents happen, Flash Voyager USB 3.0 is water-resistant.
Unlike traditional storage media, flash drives are solid-state, so they can easily handle the everyday — and not so everyday — drops and bumps that come with the territory.
Convenient and compatible
It works with Microsoft® Windows®, Mac OS X® and even Linux without drivers, and there's no software to install — just plug it in, and go. If your computer has a USB 2.0 or USB 3.0 connector, you can use Flash Voyager USB 3.0.
Fast
Access videos, pictures and large files up to 4x faster read speeds than traditional USB 2.0 drives. -
Durable
Corsair's proprietary all-rubber housing is extremely durable, water resistant and drop-tested for worry-free transport of your valuable data. -
Shock proof
Solid state storage makes flash voyager drives virtual shock proof. -
Compatible
Designed for USB 3.0, backward compatible with USB 2.0.
- CORSAIR Flash Voyager USB 3.0 - USB flash drive - 256 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 256 GB
- OS Required
- Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 256 GB
- Read Rate
- Up to 190 MB/s
- Write Rate
- Up to 90 MB/s
- Interface Type
- USB 3.0
- Shockproof, water resistant, rubberised
- OS Required
- Limited warranty - 5 years
- 0 °C
- 50 °C
