Corsair 1GB (1x1GB) DDR1 533Mhz CL4 Value Select  240 Pin Desktop Memory Module
Quicklinx: 3G0HWS00 Mfr#: VS1GB533D2
Corsair Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop systems.
CORSAIR Value Select - DDR2 - module - 1 GB - DIMM 240-pin - 533 MHz / PC2-4200 - unbuffered
Memory module
1 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
533 MHz (PC2-4200)
Unbuffered
ABIT AL8, AW8, LP-80, 81, NI8; AOpen i915; ASUS P5AD2, P5LD2, P5ND2, P5WD2; Biostar N4SIE, P4TAW; Chaintech V925, Z925; ECS 915, PF21, PF4; EPoX EP-5EGA+, 5LWA+, 5NVA+; FIC Crusader II CS2; Foxconn 915A01, 915M03, 925A01; Gigabyte GA-8I945, 8I955, 8N-SLI; MSI 945, 955, P4N; SUPERMICRO SUPER P8SCi
1 GB
Upgrade Type
Generic
DRAM memory module
DDR2 SDRAM
DIMM 240-pin
Speed
533 MHz (PC2-4200)
Non-ECC
Unbuffered
Module Configuration
128 x 64
Compatible Slots
1 x memory - DIMM 240-pin
ABIT AA8 DuraMAX, AA8-3rd Eye, AA8XE, AL8, AW8, AW8-MAX, Fatal1ty AA8XE, LP-80, LP-81, NI8 SLI , AOpen i915Ga-EFRII, i915Pa-EFRII , ASUS P4GD1, P5AD2 Deluxe, P5AD2 Premium, P5AD2-E Deluxe, P5AD2-E Premium, P5GD2, P5GD2 Deluxe, P5GD2 Premium, P5GDC Deluxe, P5GDC-V Deluxe, P5LD2 AiLife Series, P5ND2-SLI Deluxe, P5WD2 AiLife Series, P5WD2 Premium AiLife Series , Biostar N4SIE-A7, P4TAW Extreme, P4TGP 775 , Chaintech V925X ZENITH VE, Z925X ZENITH , DFI 925X-T2, UT 915P-T12 , ECS 915G-A, 915P-A, PF21 Extreme, PF4 Extreme , EPoX EP-5EGA+, EP-5LWA+, EP-5NVA+ SLI , FIC P4M-915GD1, P4M-915GD2, P4M-915PD1, P4M-915PD2 , FIC Crusader II CS2-P4M915GD1, CS2-P4M915GD2 , Foxconn 915A01-P-8EKRS2, 915M03-G-8EKRS2, 925A01-8EKRS2 , Gigabyte GA-8AENXP-D, GA-8ANXP-D, GA-8GPNXP Duo, GA-8I915P Duo Pro, GA-8I915P Duo Pro-A, GA-8I915P Duo-A, GA-8I915P-MF, GA-8I945G, GA-8I945G PRO, GA-8I945GMF, GA-8I945P Dual Graphic, GA-8I945P PRO, GA-8I945P-G, GA-8I955X PRO, GA-8I955X Royal, GA-8N-SLI Royal , Intel Desktop Board D915GEV, D915GUX, D915PBL, D915PCM, D915PCY, D925XBC, D925XCV, D925XEBC2, D925XECV2 , MSI 915G Combo-FR, 915G Neo2 Platinum, 915P Combo-FR, 915P Neo2 Platinum, 915P Neo2-FR, 925X Neo Platinum-54g, 925XE Neo Platinum, 945P Neo-F, 945P Platinum, 955X Platinum, P4N Diamond , Soltek SL-915GPRO-FGR , SUPERMICRO SUPER P8SAA, P8SCi , Tyan Tomcat i925X S5130
