Corsair 1GB (1x1GB) DDR1 400Mhz CL3 Value Select SODIMM  200 Pin Notebook Memory Module
Quicklinx: 50TZWS00 Mfr#: VS1GSDS400
Corsair Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop systems.
CORSAIR Value Select - DDR - module - 1 GB - SO-DIMM 200-pin - 400 MHz / PC3200 - unbuffered
Memory module
1 GB
Memory Type
DDR SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
400 MHz (PC3200)
Unbuffered
1 GB
Upgrade Type
Generic
DRAM memory module
DDR SDRAM
SO-DIMM 200-pin
Speed
400 MHz (PC3200)
Non-ECC
Unbuffered
Module Configuration
128 x 64
Compatible Slots
1 x memory - SO-DIMM 200-pin
