Corsair Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop systems.
- CORSAIR Value Select - DDR - module - 1 GB - SO-DIMM 200-pin - 400 MHz / PC3200 - unbuffered
- Product Type
- Memory module
- Capacity
- 1 GB
- Memory Type
- DDR SDRAM - SO-DIMM 200-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 400 MHz (PC3200)
- Unbuffered
- Limited lifetime warranty
- Capacity
- 1 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR SDRAM
- Form Factor
- SO-DIMM 200-pin
- Speed
- 400 MHz (PC3200)
- Non-ECC
- Unbuffered
- Module Configuration
- 128 x 64
- Compatible Slots
- 1 x memory - SO-DIMM 200-pin
