Corsair Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop systems.
- CORSAIR Value Select - DDR - module - 1 GB - DIMM 184-PIN - 400 MHz / PC3200 - unbuffered
- Product Type
- Memory module
- Capacity
- 1 GB
- Memory Type
- DDR SDRAM - DIMM 184-PIN
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 400 MHz (PC3200)
- Latency Timings
- CL3
- Unbuffered
- Limited lifetime warranty
- Designed For
- ABIT AN8, Fatal1ty AN8, GD8; AOpen AX4BR; ASUS A8N, P4P800; ECS 661, 755, 848, 865, 915, K8M800, K8T800, KM400, KT600, KV1, KV2, L4IGEA2, N2U400, P4IBAD2, PM800, PT800, RS400, RS480; EPoX EP-9HEAI; FIC VC37; Gigabyte GA-8GVMT4, 8I845, 8I848, 8PE800; MSI K8N Neo3-F; SOYO SY-P4I865, P4I875, P4RS350
- Capacity
- 1 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR SDRAM
- Form Factor
- DIMM 184-PIN
- Speed
- 400 MHz (PC3200)
- Latency Timings
- CL3
- Non-ECC
- Unbuffered
- Module Configuration
- 128 x 64
- Compatible Slots
- 1 x memory - DIMM 184-PIN
- Designed For
- ABIT AN8, AN8 SLi, AN8 Ultra, AS8-3rd Eye, AX8, BE7, Fatal1ty AN8, Fatal1ty AN8 SLi, GD8, IG-80, IG-81, KU8, KV8 Pro-3rd Eye, KW7, KW7-G, NF8, NF8-V, SG-80, SI-1Ns42, SI-1Ns60, VA-20, WI-1P , AOpen AX45F-4DL, AX4BR-U, AX4SG-UL, AX4SPE-UL, i865Gm-I, i865Gm-IL, i865PEa-7IF, i915Ga-E, MX46-800L, MX4SG-4DL, MX4SG-4DN, MX4SGI-4DL, MX4SGVI-N, n250a-FR, s651m, s661FXm, s661FXm-S , ASUS A7S8X-MX, A7V266E/AA, A7V600 SE, A8N-E, A8N-SLI Deluxe, A8N-SLI Premium, A8V-E Deluxe, K8N, K8S-MX, K8V-X, P4P800 SE, P4P800S-X, P4P800-X, P4PE2-X, P4S800D-X, P4U800-X, P5RD1-V, P5RD1-V Deluxe , ECS 661FX-M7, 741GX-M, 755-A, 848P-A7, 865G-M, 865-M7, 865PE-A7, 915G-A, 915G-M, 915P-A, K8M800-M2, K8T800-A, KM400-M2, KN1 Extreme, KT600-A, KV1 Deluxe, KV2 Extreme, L4IBME, L4IBMG2, L4IGA2, L4IGEA2, L4IGEM2, L7VTM, N2U400-A, NFORCE4-A939, P4IBAD2, PM800-M2, PT800CE-A, RS400-A, RS480-M , EPoX EP-5EGA+, EP-8HDA5+, EP-8RDA6+ Pro, EP-8VTAI, EP-9HEAI, EP-9NDA3+, EP-9NPA+, EP-9NPA+ Ultra, EP-9NPAJ , FIC K7-NF2 400 PRO, K8M-800M, K8M-800T, K8M-NF3 250, KT-400A, P4-865P Ultra, P4I-845GV, P4M-800T2, P4M-865G Max III, P4M-865GV, P4M-865P ULTRA, P4M-915GD1, P4M-915GD2, P4M-915PD1, P4M-915PD2, PTM865, VC37GV, VG33, VI35L , FIC Crusader CS-P4M865G , Gigabyte 8S648FXP-RZ, GA-7NF-RZ, GA-7VT600F, GA-8GVMT4, GA-8I845GV-C, GA-8I845PE Pro, GA-8I848P, GA-8I865P, GA-8I865PE-L, GA-8I865PE-TW, GA-8I865P-G, GA-8I915P Duo Pro-A, GA-8IPE1000 Pro2-W, GA-8IPE1000MT, GA-8PE800 PRO-R, GA-8TRS350MT, GA-K8N ULTRA-SLI, GA-K8NS Pro, GA-K8NXP-9, GA-K8NXP-SLI , Intel Desktop Board D845PECE, D865PERC, D865PESO, D915GAG, D915PSY , MSI 865GVM2-LS, 865PE NEO3-F, 915G Combo-FR, 915GM-FR, 915PM-ILR, K8N Neo3-F, K8N Neo4 Platinum/SLI, K8N Neo4-F, K8T Neo2-FIR, PT880 Neo-FSR, RS480M2-IL, RX480M2 , SOYO SY-CK8 DRAGON Plus, SY-K7VME, SY-KT880 DRAGON 2, SY-P4I 845PE, SY-P4I865PE Plus DRAGON 2 (Prescott-Ready), SY-P4I875P DRAGON 2 Black Label (Prescott-Ready), SY-P4RC350, SY-P4RS350, SY-P4VTP
Customer reviews
Write a review for the Corsair 1GB (1x1GB) DDR1 400Mhz CL3 Value Select 184 Pin Desktop Memory Module here!
deceptive picture
Reviewed by Anonymous Review Posted 26/12/2005
fast memory for the price. this is NOT 2 x 512m as the picture would suggest, it is 1 x 1024m.
Overall
Ease of use
Value for money
Great
Reviewed by . Review Posted 15/02/2006
Easy to install system picked it up straight away although had to manually change the speed in bios
Overall
Ease of use
Value for money
its hot stuff literally
Reviewed by Gaz Hart. Review Posted 08/06/2006
i bought one of last month and have no problems with the memory itself but the actual heat ot gives off has resulted in buying a new case, the 1 fan and my old case could not dissipate the heat however my new case has a fan on the rear and side and can cope with the heat
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
