Product
Corsair 1GB (1x1GB) DDR1 400Mhz CL3 Value Select  184 Pin Desktop Memory Module
Customer rating: 5.0* (Write a review)
Quicklinx: 3PCLWS00 Mfr#: VS1GB400C3
Corsair Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop systems.
CORSAIR Value Select - DDR - 1 GB - DIMM 184-PIN - unbuffered
RAM memory
1 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
400 MHz (PC3200)
Latency Timings
CL3
Unbuffered
ASUS P4P800; Chaintech 7KJD; ECS 661, 755, 848, 865, 915, K8M800, K8T800, KM400, KT600, KV1, KV2, N2U400, P4IBAD2, PM800, PT800; FIC VC37; PCCHIPS M906, M909, M952, M963; Shuttle SB51, SB52, SB62, SB65, SB75, SB81, SN41, SN45, SN85, SN95; SOYO SY-P4I865, P4I875, P4RS350; SUPERMICRO SUPER P4SCT
1 GB
Upgrade Type
Generic
DRAM
DDR SDRAM
DIMM 184-PIN
Speed
400 MHz (PC3200)
Latency Timings
CL3
Non-ECC
Unbuffered
Module Configuration
128 x 64
Compatible Slots
1 x memory - DIMM 184-PIN
ABIT AN8, AN8 SLi, AN8 Ultra, BE7, Fatal1ty AN8, Fatal1ty AN8 SLi, GD8, KU8, SG-80, SI-1Ns42, SI-1Ns60 , Albatron PX845EV1 Pro Rev:800, PX845EV1 Rev:800, PX845G Pro II, PX845GE Pro II, PX845GE ProIIS(Silver), PX845GEV, PX848PV, PX865P, PX865PE Lite, PX865PE7, PX865PEL-800 , AOpen AX4BR-U, MX46-800L, MX4SG-4DL, MX4SG-4DN, MX4SGVI-N , ASUS A7V266E/AA, A8N-E, A8N-SLI Premium, P4P800 SE, P4S800D-X, P5RD1-V, P5RD1-V Deluxe , ASUS Pundit R , Biostar M7VIG 400, M7VIT 800, M7VIT PRO, P4TGP 775, P4TSE Pro, P4VTG , Chaintech 7KJD, 7VIL4, 7VJL5, 9SIF8, SPT800, VNF4 , DFI 648-ALE, 648FX-AL, 648FX-ALE, 661FX-MLVE, 845GV-MLV, K8M800-MLV, NB76-TC, NB78-BL/B, nF4 SLI-DR, PT800-AL, PT880-AL, UT nF3 250Gb, UT nF4 SLI-D, UT nF4 Ultra-D , ECS 661FX-M7, 755-A, 848P-A7, 865-M7, 865PE-A7, 915G-A, 915G-M, 915P-A, K8M800-M2, K8T800-A, KM400-M2, KN1 Extreme, KT600-A, KV1 Deluxe, KV2 Extreme, L4IGEA2, L4IGEM2, L7VTM, N2U400-A, NFORCE4-A939, P4IBAD2, PM800-M2, PT800CE-A, RS400-A, RS480-M , EPoX EP-5EGA+, EP-9HEAI, EP-9NPA+, EP-9NPA+ Ultra, EP-9NPAJ , FIC K8M-NF3 250, P4I-845GV, VC37GV , FIC Golden Eagle GE-VL35G , FIC ICE-Cube HU61 , FIC Solomon II SL2-915GD1 , Foxconn 875A02-6EKRS, 915A03-P-8EKRS, 915M07-G-8EKRS , Gigabyte 8S648FXP-RZ, GA-7VT600F, GA-8GVMT4, GA-8I845GV-C, GA-8I845PE Pro, GA-8I848P, GA-8I865P, GA-8IPE1000 Pro2-W, GA-8PE800 PRO-R, GA-K8N ULTRA-SLI , Iwill MP4SG2, P4E, P4G, P4GS, P4HT2, P4HT-S, P4SE2, P4SE-Gold, P4SP, P4SP2 , MSI K8N Neo3-F, K8N Neo4-F , PCCHIPS M852, M906HLU, M909G, M952, M963G , PCCHIPS TidalWave T12 , Shuttle SB51G, SB52G2, SB62G2, SB65G2, SB75G2, SB81P, SN41G2, SN45GV2, SN85G4V2, SN95G5 , Shuttle XPC P 8100G, SB86i, SN45GV3 , Soltek SL-865GVI-L, SL-86SPE4-L, SL-B7A-F, SL-B8A, SL-B8E-F2, SL-B8E-FGR, SL-PT880Pro-FGR, SL-XP865G-3IG , SOYO SY-P4I 845PE, SY-P4I865PE Plus DRAGON 2 (Prescott-Ready), SY-P4I875P DRAGON 2 Black Label (Prescott-Ready), SY-P4RS350 , SUPERMICRO SUPER P4SCT, P4SGR , Syntax SV266AD
Customer reviews
Write a review for the Corsair 1GB (1x1GB) DDR1 400Mhz CL3 Value Select 184 Pin Desktop Memory Module here!
deceptive picture
Reviewed by Anonymous Review Posted 26/12/2005
fast memory for the price. this is NOT 2 x 512m as the picture would suggest, it is 1 x 1024m.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Great
Reviewed by . Review Posted 15/02/2006
Easy to install system picked it up straight away although had to manually change the speed in bios
  • Overall 5*
  • Ease of use 4*
its hot stuff literally
Reviewed by Gaz Hart. Review Posted 08/06/2006
i bought one of last month and have no problems with the memory itself but the actual heat ot gives off has resulted in buying a new case, the 1 fan and my old case could not dissipate the heat however my new case has a fan on the rear and side and can cope with the heat
  • Overall 5*
  • Ease of use 3*
  • Value for money 4*
Read all 5 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
