Corsair 16GB Flash Padlock Secure 256-bit AES Encryption USB3.0 Drive
Quicklinx: CF21WS00 Mfr#: CMFPLA3-16GB
Corsair's Flash Padlock gives users the confidence of having a hardware-secured lock to protect their data on an USB drive. Featuring auto-lock hardware security, Flash Padlock is the best way to secure your data while on the go. This prevents any unauthorized access or "Brute Force" attack to the data on Flash Padlock. Users can program in a PIN, much like they do for an ATM machine, to lock/unlock their data. An easy to use keypad in conjunction with lock/unlock indicator lights makes the Flash Padlock highly intuitive to use. Lastly, the Flash Padlock is fully plug-and-play, and requires no software or drivers to work properly.
  • Water resistant, shock proof, and completely secure
    Secure, shockproof, water resistant, the PADLOCK 3 USB 3.0 is a high performance flash drive designed to hold confidential and sensitive information.
  • 256-bit AES hardware encryption
    Fast encryption and strong data protection effectively secures 100% of data
  • FIPS 197
    Meets government level security standards including the Federal Information Processing Standard (FIPS) 197 requirement
  • Ruggedized rubber housing
    Water resistant and shockproof ensures data protection in extreme conditions
  • Platform independent authentication
    No need for special driver or administration rights and fully compatible with Microsoft Windows, Mac OS X, and Linux
  • PIN pad
    Built-in PIN pad provides simple authentication with no additional software required
  • USB 3.0
    Ultra-fast read and write performance over USB 3.0 connection
CORSAIR Flash Padlock 3 - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
16 GB
Hardware Encryption
Encryption Algorithm
256-bit AES, FIPS 197
Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8.1, Windows 10
5-year warranty
USB flash drive
Storage Capacity
16 GB
Hardware Encryption
Interface Type
USB 3.0
Shockproof, water resistant, customizable PIN, ruggedized
Limited warranty - 5 years
150 g
