Corsair's Flash Padlock gives users the confidence of having a hardware-secured lock to protect their data on an USB drive. Featuring auto-lock hardware security, Flash Padlock is the best way to secure your data while on the go. This prevents any unauthorized access or "Brute Force" attack to the data on Flash Padlock. Users can program in a PIN, much like they do for an ATM machine, to lock/unlock their data. An easy to use keypad in conjunction with lock/unlock indicator lights makes the Flash Padlock highly intuitive to use. Lastly, the Flash Padlock is fully plug-and-play, and requires no software or drivers to work properly.
Water resistant, shock proof, and completely secure
Secure, shockproof, water resistant, the PADLOCK 3 USB 3.0 is a high performance flash drive designed to hold confidential and sensitive information. -
256-bit AES hardware encryption
Fast encryption and strong data protection effectively secures 100% of data -
FIPS 197
Meets government level security standards including the Federal Information Processing Standard (FIPS) 197 requirement -
Ruggedized rubber housing
Water resistant and shockproof ensures data protection in extreme conditions -
Platform independent authentication
No need for special driver or administration rights and fully compatible with Microsoft Windows, Mac OS X, and Linux -
PIN pad
Built-in PIN pad provides simple authentication with no additional software required -
USB 3.0
Ultra-fast read and write performance over USB 3.0 connection
- CORSAIR Flash Padlock 3 - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 16 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES, FIPS 197
- OS Required
- Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8.1, Windows 10
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- Interface Type
- USB 3.0
- Shockproof, water resistant, customizable PIN, ruggedized
- OS Required
- Limited warranty - 5 years
- 150 g
