Corsair 16GB DDR3 1333 D/KIT VALUE
Quicklinx: 9H7YWS00 Mfr#: CMV16GX3M2A1333C9
The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
CORSAIR Value Select - DDR3 - kit - 16 GB: 2 x 8 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
Memory kit
16 GB: 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9 (9-9-9-24)
Dual channel, unbuffered
Voltage
1.5 V
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
