Vengeance Performance Memory modules, 16GB (4x4GB) DDR3 1866MHz CL9 Unbuffered DIMM Memory with XMP 1.3 for AMD, Intel Dual and Quad Channel 2nd Generation Intel Core Processor platforms. Every Vengeance memory module provides users with outstanding performance and high quality. Vengeance memory modules are built using carefully selected DRAM to allow excellent overclocking performance and rock solid stability. Compatible with AMD, Intel P67, Z68 and X79 platforms.
- 16GB (4x4GB) DDR3 for Intel quad channel platforms
- 1866MHz with headroom to allow overclocking
- 1.5V
- 9-10-9-27 latency
- Vengeance Red heat spreader for styling and performance
- Intel XMP 1.3 (Extreme Memory Profile) Support
- Also compatible with Intel and AMD dual channel DDR3 Platforms
- 10 Years Manufacturers Warranty
Spec
- Density: 16GB (4x4GB Module)
- Speed: 1866MHz
- Timing: 9-10-9-27
- Type: DDR3
- XMP: version 1.3
- Format: DIMM
- Pin Out: 240 Pin
- Voltage: 1.5V
- Warranty: 10 Years Manufacturers Warranty
Great looking, great overclocking memory
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig. -
Optimized for compatibility with the CPUs and motherboards
Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
- CORSAIR Vengeance - DDR3 - kit - 16 GB: 4 x 4 GB - DIMM 240-pin - 1866 MHz / PC3-15000 - unbuffered
- Product Type
- Memory kit
- Capacity
- 16 GB: 4 x 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1866 MHz (PC3-15000)
- Latency Timings
- CL9 (9-10-9-27)
- Dual channel, Vengeance heatspreader, Intel Extreme Memory Profiles (XMP 1.3), quad channel, unbuffered
- Voltage
- 1.5 V
- Limited lifetime warranty
- Capacity
- 16 GB: 4 x 4 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL9 (9-10-9-27)
- Non-ECC
- Voltage
- 1.5 V
- Compatible Slots
- 4 x memory - DIMM 240-pin
