Flash Voyager Mini is the tiny USB flash drive with full-size USB 3.0 performance. The USB 3.0 connector allows for optimal file transfer speed with advanced systems, and it's fully compatible with USB 2.0. It has a detachable loop for attaching to your key ring, and the durable brushed metal housing resists wear and tear.
USB 3.0 performance
It's small, but it gives you full-size speed. Enjoy optimized performance when it's connected to a USB 3.0 port. -
Compact size
It goes almost anywhere and you won't think about it when you're not using it. -
Brushed metal housing
The sleek design protects your data and resists wear and tear. The logo is laser-etched, so it won't rub off. -
Key ring convenience
The Mini has a rubber strap and metal loop for attaching to your key ring. You might never say "I left my USB flash drive at home" again.
- CORSAIR Flash Voyager Mini - USB flash drive - 128 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 128 GB
- OS Required
- Linux, Apple MacOS X, Microsoft Windows
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 128 GB
- Interface Type
- USB 3.0
- Metal body, key ring loop
- OS Required
- Limited warranty - 5 years
- 3.2 cm
- 15 g
